stock rockers for the comp 306 cam?
Old Oct 24, 2007 | 12:25 PM
mvvette97's Avatar
or is the slot not long enough for the lift?
Old Oct 24, 2007 | 01:47 PM
30696bird's Avatar
I used my stock rockers for AT LEAST 6 months. No problems.
Old Oct 24, 2007 | 03:54 PM
hotrod18_69's Avatar
There not a problem, just depends on what spring size your running..
Old Oct 24, 2007 | 06:40 PM
mvvette97's Avatar
they are the beehive PAC spring. I had a guy say that the cam has too much lift for the stock rockers. Didn't know if that was true or if it was just his guess.
Old Oct 24, 2007 | 06:45 PM
dangalla's Avatar
with those springs you might as well opt for some 1.6's and get what you paid for out of the cam
Old Oct 24, 2007 | 06:47 PM
mvvette97's Avatar
yea well if the stockers will work then that will have to work for a while. Doing a complete rebuild to a 383 so the money is getting tight.
Old Oct 24, 2007 | 06:49 PM
dangalla's Avatar
yeah trust me i understand that comepletely, i just did all this at once vvv
but honestly valvetrain is the last place you want to cut corners
Old Oct 24, 2007 | 07:15 PM
mvvette97's Avatar
yea I learned that on my LS1 but will running the stock rockers be bad as in cause damage?
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
canbaufo
May 25, 2015 12:01 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
