Stock Rev limiter
Old Feb 27, 2005 | 02:27 PM
94NDTA's Avatar
Stock Rev limiter
What is the stock rev limiter on a 1994 A4?
Also, what are the stock shift points?
I have been searching, but have only found out this info for M6's.
Old Feb 27, 2005 | 04:33 PM
94NDTA's Avatar
Re: Stock Rev limiter
Bump...someone has to know this.
Old Feb 27, 2005 | 04:39 PM
madwolf's Avatar
5886 for 1st gear
5805 for 2-4 gears
shift points will depend on the transmission (mileage, fluid, wear, etc), but they will vary anywhere from 5675 to 5825. Usually 5700-5750 though.
Keep in mind the stock tach is off by about 300 rpm so deduct 200-300 from what it shows at WOT and you get your shift points.
The following are WOT MPH shift points for 94 A4 3.23 gears:
1-2 - 36 MPH
2-3 - 73 MPH
3-4 - 126 MPH
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
