Stock rev limiter?
Old Aug 24, 2003 | 09:07 PM
showtime89's Avatar
Stock rev limiter?
What would the stock rev limiter be set at on my car? M6
Old Aug 24, 2003 | 09:53 PM
HardcoreRM125's Avatar
Im pretty sure its around 5800 ACTUAL RPM's . but due too inaccuracies of the stock Tach, most guys stock say they shift at when the tach reads 5600ish ... Even though the engine is revving a little bit higher then 5600, the factory tach reads it a little low.
Old Aug 25, 2003 | 10:05 AM
Stock rev limiter in the M6 is:
1st gear - 5,886rpm
2-6th gear - 5,805rpm
Old Aug 25, 2003 | 06:50 PM
showtime89's Avatar
thanks,
I was having some questions as to where I could shift at. I had been shifting at 5400 at the track, but I took 2nd to 6K(stock tach) on the street before I shifted and it seemed fine. I know, I should get on a dyno and see my curves, but haven't got to do that yet.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
