Stock piston/rod weight??
Old Sep 9, 2006 | 07:49 PM
marshall93z's Avatar
Anyone know what the stockers weigh? Together, or seperate...doesn't matter. Whatever you have!
Old Sep 9, 2006 | 07:57 PM
MachinistOne's Avatar
Re: Stock piston/rod weight??
Stock LT1 Piston - 532g
Stock LT4 PM rod - 603.5g/ 422 big end
Stock GM forged - 604g/ 422 big end
Old Sep 9, 2006 | 09:09 PM
Thanks man!
What are you calling "GM Forged"? The early year LT1 rods?
Old Sep 9, 2006 | 09:13 PM
Yeah - the early traditional forgings with the balance pad on the big end.
Old Sep 9, 2006 | 09:50 PM
Do you know what kind of rod this is? It is ~.070 thicker than a stock rod from a 93 LT1(on the bottom). Has different markings too. Came out of an LT1, but the guy said it was an "upgrade" from the stock 94 rods.
Stock 93 on the bottom
Old Sep 10, 2006 | 07:55 AM
96capricemgr's Avatar
93s I think got "pink" rods(70s LT-1 rods) where later LT1s got the stronger powdered metal.
Old Sep 11, 2006 | 09:02 PM
No one can identify these rods?!
Old Sep 12, 2006 | 04:21 PM
I'm not gonna give up!
Someone at least tell me I'm an idiot for thinking someone could identify a rod by looking at pics of it!
Old Nov 30, 2006 | 07:21 PM
Ttt...
Someone HAS to know!
Old Dec 1, 2006 | 05:47 AM
quickSS's Avatar
I'll give it a try.
That's not a stock LT1 rod from any year.
It's a cheaper aftermarket replacement of unknown source.
My guess.
Karl
Old Dec 1, 2006 | 09:02 AM
SStrokerAce's Avatar
Dam, now add in the weight of the stock pin and you have some mass floating around out there. One reason why the aftermarket stuff and stock LS1 stuff lives longer at higher RPM. Last time I checked the LS1 stock piston was 410g range with a 160g pin, while the rod was in the same ballpark as the LT1 rod. Thats a ton less mass right there! Makes it easy to twist a motor higher on a stock crank when all the parts are lightened up.
Bret
Old Dec 1, 2006 | 09:06 AM
WS Sick's Avatar
92-94 LT1 rods stink, they have the slimmer beam (as shown in the photo).
The thicker rod you have shown looks like the early style Pink rods, but without the look of a GM factory rod, I'll bet they are some "Renegade" or "Cat" type companys rod.
Old Dec 1, 2006 | 09:48 AM
lethal93ta's Avatar
Originally Posted by quickSS
I'll give it a try.
My guess.
Karl
for not being a stock rod a lot of us 93 guys have the same rods in there, there just stock early GM forged rods.
Old Dec 3, 2006 | 11:52 AM
You talking about the thicker one?
Old Dec 3, 2006 | 11:55 AM
I'll give it a try.
My guess.
Karl
It says "GM" on it! See it on the rod?
