Stock Oil Pan replacement...
Old Mar 17, 2005 | 03:03 AM
Silvershark's Avatar
I am looking to replace my stock oil pan with a chrome oil pan, however I wasnt sure If we had to get a certian pan because of the cross member problem that we run into with most pans.
I was curious if a 86 year and up pan would work fine or if our oil pan is made specially for our lt1's. If someone could clarify this I would appreciate it.
Here is an example of a pan I was looking at for a replacement stock pan.
Thanks.
http://cgi.ebay.com/ebaymotors/ws/eB...category=38657
Old Mar 17, 2005 | 04:46 AM
disco192's Avatar
Re: Stock Oil Pan replacement...
it should fit, the only problem would be that it does not have a spot for the low oil sending unit.
Old Mar 17, 2005 | 08:30 PM
Thats ok, I broke mine when I pulled it out doing the rebuild. I can more than likely program it out and just check my oil level manually. I dont have any need for an oil light. If I am running it that lean on oil I am going to have more problems than just a little light flashing at me.
Thanks for the info, now I can get that chrome oil pan.
HectorM52
Jul 30, 2017 11:46 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
