stock lifters and high spring pressure
Old Nov 26, 2003 | 04:55 PM
97Z-M6's Avatar
what is the most spring pressure a stock lifter can handle.
and what spring and pressure are you guys running on stock lifters.
Old Nov 26, 2003 | 09:52 PM
NightTrain66's Avatar
if the lifters are in descent shape, 135 lbs on the seat and 350 open will be fine. I have seen some set up at 400 lbs open and not have problems. Most cams will work with this amount of pressure.
If you get a cam that calls for more pressure, I would get some R lifters to be safe. I would hate to spend good $$$ on an aggressive cam and bad *** springs only to have the lifter collapsing instead of opening the valves. Even though the cam specs may be larger, if the lifter is collapsing, you will be better off with a smaller (or less radical) cam that works with less pressure and eliminates this problem.
NightTrain66
Old Nov 26, 2003 | 11:27 PM
97Z-M6's Avatar
thanks agian man.
i will be getting the heads tuesday so i may be able to get them to you that weekend.
HectorM52
Jul 30, 2017 11:46 AM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
