stock lifters and 1/4 turn preload?
Old May 14, 2006 | 07:45 PM
93camaroLT1's Avatar
I've been having problems with getting enough vaccuum out of my car for it to run properly.. I know stock the recommended preload is a 1/2-3/4 turn of preload, but wanted to see if i'd be able to get more vaccuum by only 1/4 turn of preload (I think it might have the lifter bottomed out and be holding a valve slightly open.) Would a 1/4 turn be sufficient preload for the stock lifters and not cause the rockers to "tick"?
Old May 14, 2006 | 07:54 PM
SStrokerAce's Avatar
Re: stock lifters and 1/4 turn preload?
yes the less vacuum you have the better. Even zero lash will work.
Bret
Old May 14, 2006 | 09:29 PM
Bret
I take it you meant "the less preload I have the better"...
Old May 14, 2006 | 10:30 PM
Demus's Avatar
I'm running 1/4 turn preload on stock lifters with 7/16 studs. There's very minimal noise from the valve train.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
