stock 97 formula with 4:10's
Old Apr 18, 2009 | 02:47 PM
mightymouse383's Avatar
I have a stock 97 formula and it did have a 3:42 gear in the rear, i took it to the track about a month ago for the first time. I ran a 14.5 in the 1/4 @ 99.5 mph and my 60' was 2.6, I have since installed 4:10s and am wondering what kind of gain if any can expect to see?
The car is a m6 and has goodyear 245/50/16's in the rear, I know the 60' sucked and the 4:10s might make it worse, just need to know what kind of mph i will see at the top......thanks
Old Apr 18, 2009 | 04:18 PM
Gtpguy's Avatar
You will see a gain of maybe 1-3 tenths, IF you can get good traction. Get some DRs and some lower control arm relocator brackets and you should be set until you get some serious mods that require even more traction mods.
Old Apr 18, 2009 | 09:51 PM
mpe331lx's Avatar
And possibly a broken 10 bolt if it hops at all
Old Apr 18, 2009 | 10:16 PM
naws's Avatar
but wouldnt the 4.10's make it easier on the rear end?
Old Apr 19, 2009 | 01:25 AM
93FIRETURD's Avatar
No not at all in fact even a little harder on it as the teeth are smaller on the gears in order to fit more of them on there to acheive the desired gear ratio.
Old Apr 19, 2009 | 01:19 PM
naws's Avatar
i was always under the impression it would be easier because the gears woudl want to spin easier so the tires move easier so there isnt as much stress on the gears cuz they move a lot easier
Old Apr 19, 2009 | 01:42 PM
Kevin Blown 95 TA's Avatar
Nope. You got it backwards. The engine gets the mechanical advantage. It's like using a longer wrench to turn a bolt. Meanwhile, the poor pinion gear gets smaller and even more spindly and weak and more stress gets put on the spider gears and axles.
Old Apr 19, 2009 | 02:10 PM
Air-Adam's Avatar
You have it backwards actually... a 4.10 set has fewer teeth on the pinion gear VS a 3.42 pinion gear - ring gear has the same number. IIRC:
3.42 = 12/41 teeth
4.10 = 10/41 teeth
Old Apr 23, 2009 | 10:19 PM
naws's Avatar
3.42 = 12/41 teeth
4.10 = 10/41 teeth
nice.. i take the win
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Cam's maro
Jan 30, 2015 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
