Stock '95 Z28, what should they run in the 1/4?
So what should a stock 1995 Z28 run? For those that don't know I'm very new to the LT1, so I'm not sure on their stock 1/4 times. Any help would be great. Thanks.
Ok, so my best of 14.9 is a little slow then!
She is a convertible though, so I would imagine it is heavier. And I am a experienced driver, not pro but it certainly wasn't my first time. I guess she needs a really good tune up.
My mods are none so far. My mph was 95.54 and I beleive my 60' was in the 2.2 range. I did notice under hard throttle she hesitates shifting gears, she seems to jump in the rpm just a little before she shifts. It that normal, has it happened to anyone else?? My gears are 2:73 and she is an auto.
i have seen lt1's go from 13.8's to 15.1 in the hot texas heat. my car went 14.4-14.5 stock. now with just a cut out and cai it goes 13.8 w/ no tires. what im saying is work on your 60' and get good tires. part of the problem is your 60' and the weight of your car, work on the 60' get a catback, and a cai with just those your 1/4 will drop .2-.5!!!!!!!!also try some free mods, you wont see big gains but every little helps.
Your mph definitely sounds low to me, but that could just be minor tune plugs/wires/airfilter/tire pressure/extra crap in the car, type stuff. <shrug>
