Are stock 3.42's enough for cc306??
Yeah, you can keep your stock gears. I'm running a pcm4less tune, with the stock gears and the 306. I can still run 55mph in 6th gear, no problem. The only problem I have...and I don't think this is gear related...is that my car jerks and surges when I'm sitting right at 1600-1700rpms. Anywhere else, it drives fine. Guess I'll have to try VEmaster.
I could do low RPM with a big cam too, but I dont like the idea at all. If we had L98s that were doing 440 RWTQ or something that might be different. I want to make sure I have some oil pressure going, and with that in mind I'd go for some gears eventually or run in 5th gear when traffic gets crappy.
I could drive my car with the 3.42 and a cam, but I was always yearning for gears.
1.) You have to slip the clutch more to get a smooth standing start on the street with 3.42.
2.) Steeper gears put you into the powerband of the cam quicker than the 3.42's.
I drove with a couple of different cams on the 3.42 gearing without headache but I'm glad I finally worked up the courage to install the 4.11's. I will say that proper tuning helped immensely with those standing starts. Now I just constantly worry about breaking the 4.11's
