Still having trouble after h/c install
Old Mar 29, 2005 | 04:31 PM
  #16
hsyr's Avatar
Re: Still having trouble after h/c install
Originally Posted by ajschult
I didnt install the opti this time around, my brother did it. I asked him if he remembered it sliding on easily and he said yes, but if its possible to get the splines off then maybe its worth another look.
I replaced my unvented opti not too long ago and from what I seen I don't think you can put it on the wrong way the way the splines go it just won't slide on. Throwing any codes?
Old Mar 29, 2005 | 04:57 PM
  #17
ajschult's Avatar
Not as far as I know. I have a laptop, but no scanning software to use. The service engine light pretty much stays on, because the car wont start right now.
Old Mar 29, 2005 | 07:42 PM
  #18
1racerdude's Avatar
Did you check the valve to piston clearance?? The only way you would bend pushrods is contact between the two. Or your springs are coil binding. Do the compression test to make sure the intake valves aren't bent or holding open.
The opti may be the no fire to #3 but if the wires are right the only thing to cause it to backfire in the intake is open or bent valves.
Nov 18, 2023 07:21 PM
Cam's maro
Mar 24, 2015 08:09 PM
Bignasty85
Mar 3, 2015 04:05 PM
alphaauto
Jan 22, 2015 08:02 PM
