Still having issues
Old Feb 2, 2009 | 05:47 PM
97sscamaross's Avatar
Still having issues
I'm getting a really bad miss whenever I put the engine under load. It does it in open loop but in closed loop it's much worse. It does it a lot worse in lower rpm but it's still does it in all rpm ranges. I've checked all my plus and wires about 10 times just to be absolutely sure. I can't figure this out for the life of me.
Old Feb 2, 2009 | 06:18 PM
ulakovic22's Avatar
ICM, Opti, Coil......
I've heard of people having issues with MSD boxes as well eating up Opti's, but I don't know, just a rumor, maybe someone else has a better explanation or experience.
Old Feb 2, 2009 | 07:13 PM
The opti is new, the icm isn't a year old, and I'll check the coil's resistance.
Old Feb 4, 2009 | 04:12 PM
Does anyone have any other ideas? I'm stumped on this one
Old Feb 5, 2009 | 05:45 AM
Guest47904's Avatar
Guest
Have you isolated it to a particular cylinder by pulling injector clips and looking for the one(s) that produce no idle change when they are disconnected?
Have you looked at any plugs to see if they show signs of fouling?
Old Feb 5, 2009 | 04:24 PM
It doesn't miss at idle and if it does it's soo minute that I can't notice it. I've pulled a few plugs and they all looked fine
Old Feb 6, 2009 | 03:24 AM
SS RRR's Avatar
It's a stretch, but have you checked fuel pressure? Possibly the pump is overheating due to going bad. Worth a shot at least...
Old Feb 6, 2009 | 04:16 PM
yeah fuel pressure is great and I check it with the vacuum line off of the regulator as well. what about a bad o2 sensor? i've never had one go out on me before but i've heard that it'll make a car run like crap if one goes out.
Old Feb 6, 2009 | 04:59 PM
SS RRR's Avatar
quite possible. if you can, get the pcm scanned. that will tell your right away if it's an 02 sensor.
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
