Still Burning Coolant
Old Jul 7, 2003 | 10:19 PM
94_Z28_guy's Avatar
Just got everything back together after blowing a head gasket. Started it up, runs really good, but started seeing white exhaust out tailpipe that is definitely coolant that gets worse as the car runs.
Could there be remaining coolant in the exhaust pipes from the blown head gasket that needs to burn off? Anyone had this happen?
Old Jul 8, 2003 | 05:21 AM
slopokrodrigez's Avatar
I think your head(s) is cracked. Seen it before. A few minutes would have burned off any remaining water. If it gets worse as the engine heats up, it's a crack. Could even be the block but I'd check the heads. Did you have the heads checked for warping before you reassembled it? That could also be a likely choice. Either way the heads got to come off.
Old Jul 8, 2003 | 06:59 AM
94_Z28_guy's Avatar
I had the heads compression checked, and milled for any warpage when I had them off before. So they SHOULD be okay.
You say all water burn off after a few minutes, I had the car running for only about 20-30 seconds then I shut the car off when I saw the smoke. Maybe I should let it run 5 min or so?
Old Jul 8, 2003 | 07:18 AM
Josh-'04 GTO's Avatar
20-30 seconds could have been coolant in the exhaust pipes etc. I would have let the car run for at least a few minutes. Did you put sealant on the head bolts?
Old Jul 8, 2003 | 08:53 AM
ollie-99's Avatar
i think its the coolant in the exhuast and all that
it needs to be burned off
Dont sweat it
Old Jul 8, 2003 | 12:37 PM
94_Z28_guy's Avatar
Thanks. I got the felpro head bolts that had white sealant on the bolts. The directions said "IF" the bolts have sealant on them you don't need any. I assume what was on there was sealant.
Dont sweat it
Thanks, I hope you're right, I am sweating it!! I'll run it tonight for a while and see what happens.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
