Steering wheel isnt 100% strait
Old Jul 21, 2003 | 09:14 PM
bigsteve7's Avatar
My steering wheel requires you to tilt it a bout 15 degrees or so to the left for the car to track strait. If I turn the wheel directly strait the car turns off to the right.
Is this caused by a misalignment? Its not a big deal, just a little peeve of mine. I'd like to get it corrected if possible.
Old Jul 21, 2003 | 09:18 PM
LPEdave's Avatar
An alignment will fix it. It's probably one wheel toed in, the other toed out.
Dave
Old Jul 21, 2003 | 09:22 PM
Camaro_Maniac63's Avatar
I had the same problem on a Chevy Blazer, it wasn't only the alignment, but the steering wheel had somehow moved off the center a little bit. Took the steering wheel out, and corrected it to the right position, and it was all fine. But you should definitely try an alignment first.
Old Jul 22, 2003 | 06:56 AM
revtime's Avatar
Alignment should fix it up, mine was off somewhat after I rebuilt the front suspension and got it aligned and fixed it right up.
Old Jul 22, 2003 | 10:53 AM
dave1w41's Avatar
It is most likely toe. If the car does not pull but the steering wheel is just off to one side, you can fix it yourself with a toe gauge and some time. The steering wheel on these cars is indexed to the steering column shaft and can only go on one way.
anasazi's Avatar
after i smacked a curb mine was worse off than that. an alignment fixed that problem...
Old Jul 23, 2003 | 12:20 AM
ZPaul2Fresh8's Avatar
Smacking a curb will throw your alignment off only if it bent something, I mean if you know how it holds together, there is no way of it "falling out" of specs. Take it from me I align about 50 cars a week, all kinds and have seen it all.
Camaro_Maniac63 Sounds like to me someone replaced the pitman arm and put it on the wrong notch on the gear box...90 degrees on the box, about 5 degrees of toe
Need an alignment? Come to my shop and I'll fix'er up
Oh, also your Camber might be off also. If there's .8+ degree split between left and right camber, then you'll get a pull, but most people would think it's toe just because you steering wheel isn't center, but that's off center to compensate your car from pulling see what I mean?
PS, get a before and after print off of your specs...
Old Jul 23, 2003 | 01:01 AM
Zack's Avatar
well, after I smacked a curb, my wheel was off 90* to the left, and the alignment was **** poor. Took it to get re-aligned, but they couldnt get the wheel completely straight, because the inner tie rod ends are bent. This happened like 3 months ago, and it still isnt fixed
Old Jul 23, 2003 | 10:34 AM
See, what I was saying
Fastbird93
Apr 9, 2016 07:01 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
Airplanedoc
Feb 1, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
