steam pipe removal.
Old May 22, 2008 | 11:17 PM
94NDTA's Avatar
steam pipe removal.
We are trying to remove the heads on my car.
For people who have taken their heads off, how the heck did you get this off!
Old May 22, 2008 | 11:30 PM
Jazsun's Avatar
I was actually just going to post up about the technique I used which took only about 10 minutes to get them both off.
Take a box wrench w/ the closed side on the nut so its sticking up in the air, then I took a 5lb mallet and wacked the wrench a couple times until It cracked the nut. Did that on both nuts and worked like a charm, no extreme force exerted by me to break them. On the driverside one I just had to use a regular box wrench to keep unbolting it. On the passenger side I could get a ratcheting box wrench on it which made it go super fast.
Old May 22, 2008 | 11:36 PM
94NDTA's Avatar
What size is the bolt?
Old May 22, 2008 | 11:40 PM
Jazsun's Avatar
I don't remember just try some box wrenches until one is real snug it should fit real snug. I am pretty sure it was a metric but not positive.
Old May 23, 2008 | 06:32 AM
maverickmk's Avatar
15mm
Old May 25, 2008 | 02:07 AM
lt1loudmouth07
Guest
Posts: n/a
steampipe
yes 15mm and also u better buy new seals and bonjoe bolts at the dealer because when u get them back on and u see it leak back there u will be very mad lol. They are fairley cheap at the dealer dont half A@@ it and make sure not to strip the threads tighting them back on
Old May 25, 2008 | 10:07 AM
ShownomercyZ28's Avatar
Or just get a partner and pull the heads with it still attached.
Old May 25, 2008 | 01:24 PM
Jazsun's Avatar
Look at your seals when you pull them, if they arn't cracked you can probably re-use them.
Old Aug 19, 2008 | 10:16 AM
Connexion2005's Avatar
I used a 15mm rachet wrench and a lot of thrust haha...
Old Aug 19, 2008 | 12:24 PM
Max Lewis's Avatar
I had to end up cutting mine off because after using the box end wrench and beating on it with every thing I could throw at it. I even used PB Blasting on them and let it soak on them for 3 days spraying them a couple of times. I went to the junk yard and got a another steam pipe off a buick roadmaster for $5 GM dealership was about $80. For some reason that one come right off I don't know if was because of the steal heads or not.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
