starts but no idle
Old Jul 3, 2005 | 10:06 PM
tkiely05's Avatar
starts but no idle
finished the heads/ cam swap but when i started it the only way it would start is if i give it gas and it wont stay running without me giving it gas. any ideas why its acting up. i know the timing is good. i dont know what else could cause this.
Old Jul 3, 2005 | 10:43 PM
tkiely05's Avatar
Re: starts but no idle
anybody? i need some help please. im running low on ideas.
Old Jul 3, 2005 | 10:57 PM
The first thing to do is make sure you did not leave anything unplugged or hoses off. Did you get a computer re-program? Maybe some more details about your setup would help.
Old Jul 3, 2005 | 11:06 PM
tkiely05's Avatar
ok, put in a cam and ported heads. i had my computer tuned by madz28. i had him delete the egr and air pump. i cant find any hoses that i may have missed.
Old Jul 3, 2005 | 11:25 PM
Rpm280's Avatar
LOL. It sounds like the all to common too tight lash (rocker arms) problem. Many of us have been there. Set the valve lash again.
Many here know and have heard the symptons many times especially after a cam install . Especially if its a first one. Car won't start or stay running unless you step on the pedal, and your throttle response is probably terrible.
Anyways, thats likely your problem.
Old Jul 4, 2005 | 11:01 AM
tkiely05's Avatar
thanks rpm280 ill try that.
Old Jul 4, 2005 | 11:20 AM
ZMAN Z28's Avatar
Try resetting the IAC.
Z
grgguy
17
Feb 23, 2015 07:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
David Dorris
Jan 17, 2015 08:10 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
