starting probs
Old Jul 6, 2003 | 04:31 PM
rotoruter2001's Avatar
starting probs
i replaced my starter, but it still is hard to get it started. it gets worse the later in the day and more times i try to start it. it will crank and try to start, but i have to give it gas to actually start.
Old Jul 6, 2003 | 05:08 PM
NeoSNK's Avatar
Sounds like a weak fuel pump or weak ignition system.
Old Jul 6, 2003 | 06:38 PM
i have not driven it yet today, but i replaced the engine coolant temp sensor. i know it has something to do with the efi, any chance that coulda been it?
Old Jul 6, 2003 | 09:13 PM
NeoSNK's Avatar
No, check your spark and listen to see if the fuel pump runs when u turn the key on.
Old Jul 16, 2003 | 12:20 AM
fozziez28's Avatar
I am having similiar problems. Plugs and wires didnt cure it. I think its fuel related almost for sure. I am gonna change my fuel filter before I jump in to replace the the fuel pump. Unfortunately I think its the pump.
Old Jul 16, 2003 | 01:00 AM
fbird95's Avatar
I had similar problems when i had evap line leaks. As the day went on and the car was hot, it got stubborn to start, not to mention the gas smell all the time.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
