Starter/Wire ques.
Starter/Wire ques.
The little black wire, assuming ground, that comes from the same grommet that the starter wires comes from where is it supposed to be connected? To the block somewhere?
Thnx.
Thnx.
Hmm..I think I found it myself after looking through shoebox site one more time, must be the pcm ground:
http://shbox.com/1/g103.jpg
Well, since you're here shoebox ...the metal piece, that the bolt that holds the pcm ground bolt goes through, what is it used for more than the pcm ground? I see a clip on there..is it for the o2 sensor harness clip?....any other use for that metal piece?
The reason I ask is because I've got it all apart and I can't remeber if there are any more use for that metal piece than the right o2 harness clip?(which I of course broke taking it off
)...Perhaps the plug wires were connected there, I'll be going ovc wires so I'm thinking of not putting the metal piece back on...
5thgen69camaro
Mar 29, 2006 03:23 PM
