Starter will not disengage LT1 swap
Old Apr 28, 2012 | 10:34 PM
cyteone's Avatar
I am trying to help a friend with his LT1 swap into a 1966 Skylark. I wired up his starter for him like this:
The big terminal on the starter gets battery positive and batt terminal on key gets battery positive.
The yellow wire goes from the back of the key to the S terminal on the starter only gets power when the key is turned to crank. There is no power on the yellow wire in any other key position.
We tried it like this and the starter would just click and not rotate. After trying the starter about 20 times and smacking it with a hammer it finally started turning the engine but when I let off the key the starter would not disengage.
We tried it a few more times and each time it would not disengage.
Is there anything wrong with the wiring?
Could a bad starter cause this?
Old Apr 29, 2012 | 01:05 AM
96z28_lt1's Avatar
Re: Starter will not disengage LT1 swap
solenoid could be bad, i believe that is what engages and disengages the gear, hitting it probably caused it to unstick though so the gear could just be sticken if you have another one around or can get a hold of one real cheap or so i'd try that
Old Apr 29, 2012 | 08:07 AM
Sounds like a sticking solenoid.
Old May 21, 2012 | 08:01 PM
cyteone's Avatar
Sticking solenoid was the cause. We got a new starter and it now works fine.
Thanks.
rocketman051894
Jan 30, 2015 03:23 PM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jeff1904
Jan 3, 2015 12:00 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
