Starter Solenoid help!
Old Jul 1, 2004 | 05:48 PM
Loadre's Avatar
Long story short the big stud broke off. Don't know how but we went to fire the new motor up and that's what is wrong.
My question - Can you just buy a new solenoid and replace it or do you have to get a whole new starter? How does the solenoid come out? Thanks.
Brian
Old Jul 1, 2004 | 06:05 PM
Spinner's Avatar
Do a search. I had a similar issue not long ago. The verdict was (after much personal searching) that you can NOT get the solonoid seperate. I soldered on a heavy gauge wire and a "deans" plug connector to the terminal, the the wire it connects to. A deans plug is used in electric RC (radio control) as a next to zero-loss heavy duty connector. Should be able to supply enough juice for the starter.
Old Jul 1, 2004 | 06:33 PM
Loadre's Avatar
I checked your thread and it looked like a couple guys got the solenoid to come out. So does it come out or not? Am I looking at getting a new starter?
Old Jul 1, 2004 | 06:36 PM
Spinner's Avatar
Some of them have been able to get it out. Some havent. The problem is, you can't BUY one.
Old Jul 1, 2004 | 10:47 PM
Though, didn't someone say they bought one at NAPA? Seems the later model starters have some torx bolts holding the solenoid on. GM does not list a replacement solenoid, though.
Old Jul 2, 2004 | 06:24 PM
Loadre's Avatar
http://www.dbelectrical.com
You drill out the holes where the solenoid is held and it comes out. The shop in that link is a shop local to me but they do internet business. They replaced the solenoid in about 10 minutes and it fired right up. It cost $32.
Old Jul 2, 2004 | 06:42 PM
Spinner's Avatar
Good info. Can't beat a $32 fix
Formula Steve
Sep 19, 2023 08:31 AM
marlar98
Sep 19, 2015 07:53 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
