Starter Solenoid
Old Aug 22, 2004 | 09:50 PM
DrewHMS97SS's Avatar
Starter Solenoid
Basically trying to find out if its possible to buy just the solenoid vs the whole starter. any info is apprciated.
Old Aug 22, 2004 | 10:11 PM
Spinner's Avatar
Re: Starter Solenoid
Short answer: No.
Do a search for my username and starter. I'm sure you can find the post
Old Aug 22, 2004 | 10:13 PM
Birdman7389's Avatar
A wise man once told me that replacing just the solenoid is aking for trouble. Says if its old enough for the solenoid to go out, your starter is bound to be pretty close. Sounds pretty reasonable. Just get a whole new starter/solenoid.
Old Aug 22, 2004 | 11:06 PM
If you have a late model starter housing (seems to be 1995 and up), it is possible. That is, if you can find a solenoid. You will be able to tell by whether your solenoid is held on by some male head torx bolts (from the rear of the housing).
Old Aug 22, 2004 | 11:24 PM
Built on Sin's Avatar
I agree with the wise man. After 3 solenoids, I finally got wise and replaced my starter. Although, That was dealing with my truck.
Old Aug 23, 2004 | 12:15 AM
Loadre's Avatar
Do a search under my username for 'starter'. Got my solenoid replaced for $32 bucks.
http://www.dbelectrical.com
Edit- and shoebox isn't entirely right. My starter was a '94 style and all they did was drill out the holes around the starter and replaced them with small screws, similiar to the ones already found on the '95+ models.
Old Aug 23, 2004 | 12:24 AM
There ya' go. There is always a way to get something done.
Old Aug 23, 2004 | 04:54 PM
cool! i thought so, the solenoid can be taken off via male torx bolts. i did end up getting a new starter for 116 from checker, i was dreading the $298 dealer item. the stater im pretty sure was fine. when i went to take off the power lead the stud broke. im talking about SMALL amount of pressure to get it to go that far.
Old Aug 23, 2004 | 05:05 PM
Loadre's Avatar
Same thing happened to me. Seems to be fairly common.
Old Aug 23, 2004 | 06:54 PM
Mtrhds94Z's Avatar
GM LT4 starter is a good option too.. 150 new from Jason Cromer..
Old Aug 24, 2004 | 12:29 AM
didnt want to spend the time, im an impatiant bastard.
Old Aug 24, 2004 | 12:34 AM
least its not just me. you say youve seen it a lot though?
Old Sep 30, 2004 | 11:09 AM
jeremyferguson's Avatar
Same exact thing happened to me Murray's sells rebuilt ones for 85 bucks, I guess I'll go that route, unless I can find somewhere locally that can fix it.
Old Sep 30, 2004 | 11:22 AM
chevyboy_z28's Avatar
Originally Posted by jeremyferguson
Murray's sells rebuilt ones for 85 bucks.
we sure do, and theyre 1 yr warranty. the bosch/master quality ones are lifetime warr. but are a lil more expensive (all are reman).
Old Sep 30, 2004 | 12:00 PM
Which one are you at? I was going to go to the one at 12 and dequindre(close to my house) but they said it would be a day to get it in....but I see your location is Detroit, and this week I'm stationed out at Detroit City Airport....
