Starter Removal Question
Old Jan 7, 2008 | 08:43 PM
texas94z's Avatar
I am in the middle removing the starter in my 94 z28. Do you have to remove the y pipe in order to drop the starter? Right now the starter is resting on top of passenger side y pipe. I dont really want to drop the y pipe if there is an easier way to get it out. Help please. Thanks.
Old Jan 7, 2008 | 08:49 PM
northdakota93z28's Avatar
ya you have to until you get long tubes. sorry
Old Jan 7, 2008 | 08:54 PM
texas94z's Avatar
thanks man. its goin to be a long night.......
Old Jan 7, 2008 | 08:55 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I'm sure we took the starter off my '94 without removing the Y-Pipe. It's been awhile. I can't recall any specifics, other than knowing we did it. My car is a six speed. I'm not sure whether that would matter.
Old Jan 7, 2008 | 08:58 PM
Tex95Z's Avatar
i did not have to on my 95
Old Jan 7, 2008 | 09:04 PM
SS RRR's Avatar
I think only the dual cat y-pipes need to be dropped. Not single.
Old Jan 7, 2008 | 09:08 PM
my 93 you had to
Old Jan 7, 2008 | 09:55 PM
texas94z's Avatar
explain. how did you do it?
Old Jan 7, 2008 | 10:01 PM
BTC's Avatar
BTC
What issues are you experiencing in your attempts to remove the starter?
Old Jan 7, 2008 | 10:13 PM
Tex95Z's Avatar
I disconnected all wires slid the starter a few inches toward the front of the motor, that allowed me to lift up the starter to about 45* , that allowed me to rotate the starter so the solenoid could just squeeze past the curve in the exhaust pipe.
Old Jan 7, 2008 | 10:18 PM
96ZCamaro's Avatar
I dont think I had to remove the Y on my car to take out the starter. (BTW, 96 lt1 6 speed, and it was stock at the time)
Old Jan 7, 2008 | 10:21 PM
Tex95Z's Avatar
I know my post above is a bit hard to read but its really more about finess than anything else. as long as it is stock it will fit out.
Old Jan 8, 2008 | 01:59 AM
GLICKGLOCKMEX's Avatar
IM with tex95z its all about finess.i have 93 z auto single cat.at first it was hell, but just keep trying to work it out it will come.i remember my process being somewhat like tex95z explained but i also had to flex my hard lines comeing from my tranny just a little to slide the starter out and the lines flexed right back.just try to work it out but if you run into my problem to dont push the limits of those lines.Good luck!!
Old Jan 8, 2008 | 02:11 AM
6SpdLT1Z's Avatar
I believe you have to on automatics. I didn't on my '97 Z28 M6.
Old Jan 8, 2008 | 07:59 AM
Craddock's Avatar
Didn't have to on my 94.
