starter motor wiring question
Old Jul 13, 2004 | 02:47 PM
joebeemish's Avatar
I am in the final stages of rebuilding my 95 Z28 LT1. My mechanic put a new starter in, and it does not spin the motor very well. The parts guy said that the starter motor for 94 and 95 LT1's are different.
Questions: I bought my car new in September 1994 from the dealer. It is listed as a 1995. Could it be a hybrid between the 1994 and 95? Are the starters different? Do they wire up differently?
Thanks.
Old Jul 13, 2004 | 02:57 PM
joeSS97's Avatar
I am sure they are pretty much all the same.It sounds like you have one or more of the following going on.A weak battery.A weak starter,or a poor connection.I would clean all the connections,check the cables too.,If that doesnt do it,Test the battery.If there is still a problem test the starter.One thing--whats the compression ratio?
Old Jul 13, 2004 | 04:46 PM
joebeemish's Avatar
9.5 to 1
Old Jul 13, 2004 | 06:40 PM
Originally posted by joebeemish
9.5 to 1
Stock is 10.5:1. Did you do something to lower yours?
Digit 10 of the VIN will tell you what year the car is. S=1995.
There has been a slight difference noted in the starter casing/solenoid mounting, but there is no difference in how they are wired. The positive battery cable goes to the large terminal on the bottom of the solenoid and the purple wire goes to the outside terminal. No other wires go on the starter.
Old Jul 13, 2004 | 07:43 PM
joebeemish's Avatar
Mr Shoebox,
Thanks. That got it running.
I am rebuilding the motor. I put a 383 stroker kit in and we lowered the compression so that it will be ready for a blower.
HectorM52
Jul 30, 2017 11:46 AM
Jan 5, 2015 07:14 PM
Jeff1904
Jan 3, 2015 12:00 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
lbrowne
Nov 13, 2011 04:25 PM
