Starter Motor help needed!?!
Old Jul 21, 2004 | 06:17 PM
Heatmaker's Avatar
Advanced Member
Starter Motor...
Anyone know the part numbers for after market Starters for LT-1
Mini or regular.... what manufacturers are good?
Old Jul 21, 2004 | 06:42 PM
95 Z/28 LT1's Avatar
Super Moderator
Re: Starter Motor help needed!?!
Originally Posted by Heatmaker
Starter Motor...
There's a great feature that this site has, and it's called the search function. You should give it a try.
Old Jul 21, 2004 | 06:51 PM
Heatmaker's Avatar
Advanced Member
I know I use it all the time... but with this new format it pulled up allot of random subjects and I spent a good 20 minutes with no luck.
Old Jul 21, 2004 | 06:56 PM
Mtrhds94Z's Avatar
Smile Re: Starter Motor help needed!?!
I highly recommend a new LT4 starter from Jason Cromer.. 150 shipped..
p/n 10455709
Old Jul 21, 2004 | 07:45 PM
Super Moderator
I've had the same problem lately. You have to go to advanced search. If you just type a word in to the search box it will search every forum. I'll see if I can get that changed.
As for starters I like the LT4 one pretty well, but currently I have one of the ones they sell at Summit or Jegs. It's a CVR, and is adjustable to clear your exhaust too.
Old Jul 21, 2004 | 08:16 PM
Heatmaker's Avatar
Advanced Member
Old Jul 21, 2004 | 10:52 PM
It would be nice if it just searched the forum you were currently in. That would be much handier. Not much point in having a quick search box if it is going to search all creation. Seems like it would save some compute cycles on the server as well.
Old Jul 22, 2004 | 07:10 AM
Heatmaker's Avatar
Advanced Member
hmmm I'm having a tough time figuring out the right aftermarket starter...
Do you know the CVR part number?
I have a Manual 6
I'm flippin through summit but none of the startes look right... atleast I can't identify what to go with.
Old Jul 22, 2004 | 08:21 AM
Super Moderator
The part # is 01715323 at Jegs. It cost me $147
Old Jul 22, 2004 | 10:58 AM
Z06Z28's Avatar
I wasn't sure if anyone has ever bought the Summit Protorque starter #820323...well the oil pan clearance is a lil off so you have to Dremel the corner a lil bit more than whats already on there.....just thought I'd throw the info out there because it doesnt fit well...other than that it works fine with no shims
Old Jul 22, 2004 | 11:38 AM
neil350's Avatar
You have to dremel off the corner on the CVR too, I had to when we put mine in.
Old Jul 25, 2004 | 02:26 PM
Super Moderator
If you look to the far right of the page when viewing a forum there is a link that you can click which says "search this forum". That's the one to use. There's also one now inside each thread that says "search this thread" too.
Edit: Whoops, right not left.
Old Jul 25, 2004 | 02:52 PM
If you look to the far left of the page when viewing a forum there is a link that you can click which says "search this forum". That's the one to use. There's also one now inside each thread that says "search this thread" too.
I must be going blind in my old age, because I see nothing but the drop down search at the top of the page (whether on the forum or in a thread).
Old Jul 25, 2004 | 02:54 PM
Super Moderator
Look at the second red bar from the top, then look to the right.
edit: right not left, doh!
Old Jul 25, 2004 | 04:46 PM
Look at the second red bar from the top, then look to the left.
LOL, I do see it on the right of the screen, but it does confirm I am going blind!
