started my new motor lastnight and it got hot
Old Sep 14, 2005 | 10:52 AM
ninety4formula's Avatar
Just started my motor for the first time lastnight and everything was going well. When I went to go drive it, within a minute the temp gauge was pegged. When I realized that I shut it off, and then Got it back to the garage and started thinking what could be wrong. Well I hate to say it but I forgot to bleed the system. Did that and its still running hot. The thermostat is only 2 years old, so idk what it could be. The radiator is cool but the motor is running hot. Any suggestions?
Old Sep 14, 2005 | 11:09 AM
Re: started my new motor lastnight and it got hot
Keep bleeding it.
Old Sep 14, 2005 | 11:12 AM
Honda Hunter's Avatar
Originally Posted by shoebox
Keep bleeding it.
Werd. I had the same problem after changing the head gaskets. Keep bleeding it, should be fine.
Old Sep 14, 2005 | 11:31 AM
We were bleeding it for like a half an hour and don't hear air coming out anymore. No fluid was coming out of the bleeder unless there was also air coming out, but now it is nothing. Could it be the thermo? What are the chances of me doing damage to my new motor already?
Old Sep 14, 2005 | 12:01 PM
ZMAN Z28's Avatar
I can't say as far as damage goes. But did you flush you radiator out when you did your rebuild. When the radiator sits dry without being flushed, all of the junk and stuff cloggs your radiator. That's atleast what the radiator shop told me to have mine inspected because mine was running warmer than normal after my rebuild. You can test you thermostat in a pot of hot water to see if it opens.
ZMAN
Old Sep 14, 2005 | 12:09 PM
1racerdude's Avatar
Ya still got the crossover tube on the back of the heads? Got a new electric WP? Fans coming on?
Old Sep 14, 2005 | 12:16 PM
The fans are kicking on, and I replaced the crossover tube so I know thats good. I didn't get the radiator flushed or baked or anything. Are the replacement radiators on ebay any good? I know they are only like $100 and mine could probably use replacing. I know that the coolant is getting to the heads because I had to change the temp sensor in the head.
Old Sep 14, 2005 | 12:47 PM
1racerdude's Avatar
If ya got a high HP unit ya might think of a larger radiator.
If not larger I would take mine to the shop and have them rot it out vs. an eBay one.
If it didn't run hot before I would keep bleeding,maybe jack the car up in the front to get the rad higher than the motor.
If ya got a new electric pump it may be turning backwards,so check the wiring.
Old Sep 14, 2005 | 12:58 PM
I have a factory waterpump. I don't think that I'm pushing to much power, at least I hope not because the aluminum radiators I've seen are $800 and thats rediculous. How much roughly does it cost to get the radiator boiled or whatever your talking about? I did have to rebuild due to a blown headgasket so maybe there is crap in there and it does need to be cleaned or replaced.
Old Sep 14, 2005 | 01:03 PM
1racerdude's Avatar
Maybe 50-60 dollars. Call a radiator shop in your area and see.That's with you taking it out.
Old Sep 14, 2005 | 01:21 PM
turbo_Z's Avatar
You could try a couple of things.
Try dumping the coolant into the filler neck.. just remover the neck and dump it in. That will bypass the thermostat and allow for most of the trapped air to be bled out. Then fire up the motor once its all back together and unscrew the brass bleed screws till you see coolant.
Old Sep 14, 2005 | 03:00 PM
ZMAN Z28's Avatar
It cost me 20.00 cash to have them test and flush mine. It cost 35.00 if I didn't pay in cash. I don't know how much to have it rod out. It probably won't be that much more. Give a radiator shop a call. It would be a lot cheaper then buying a new one, if it can be rodded or just a good flushing.
ZMAN
Old Sep 14, 2005 | 03:30 PM
Victory Racing's Avatar
Sounds like you have a bubble in the system still.
Have you tried jacking the car up in the front?
Old Sep 14, 2005 | 04:05 PM
Roscoe267's Avatar
This may sound like a stupid question but did you make sure you have the water pump splined coupler connected?
Old Sep 14, 2005 | 04:20 PM
Mikey97Z's Avatar
Trust me ... that's NOT a stupid question.
