Are "Standard" plug wires any good?
Old Aug 10, 2011 | 12:42 PM
96 TA's Avatar
I went to Parks auto store to get some plug wires for my T/A. I asked for the AC delco brand and they told me they listed at $175! The brand "Standard" which they said were pretty reputable sold for $75, thats still more than what I would expect but $100 difference has me thinking about running them. Thoughts?
Old Aug 10, 2011 | 12:51 PM
bw_hunter's Avatar
Re: Are "Standard" plug wires any good?
Standard is an American company with manufacturing all over North America. However, I can't find that they make their wire and cable products.....they may import them.
To tell the truth I wouldn't use anything but high performance wires on our cars....the routing is too much of a pain to do too many times. That doesn't mean standard wire to me, or even AC for that matter...
calaban's Avatar
I run Jeg's branded wires. They are 30 dollars a set and I've never had a single issue with them. I've been running the same set for around 5 or 6 years. It's getting about time to change them.
Not from problems, just had them on there a while, at least 40k.
They are larger than stock so they won't fit in the factory routing clips.
Old Aug 10, 2011 | 01:33 PM
6SpdLT1Z's Avatar
I'd make sure to purchase a brand you trust, as plugs and wires aren't exactly the most thing to do on a LT1 f-body. I've currently got MSD on my 97 SS. Triple check your wiring before firing it up, don't want to burn any wires!
Old Aug 10, 2011 | 01:54 PM
GRIDERMAN87's Avatar
I run Taylor 8.8's on mine they havent given me any problems, and they are not too expensive, think they were around 80 dollars, I wouldnt run anything but high pro. wires its just not worth the work involved to run oem wires
Old Aug 10, 2011 | 05:10 PM
Standard brand parts have been reputable in the past. I've never used anything but the AC-Delco wires and have never had an issue.
Old Aug 11, 2011 | 10:54 AM
deerslayinrenek's Avatar
Mine had a set of Accel race wires....idk exactly what they were but one got damaged during the header install so i went down to napa and bought the cheapest set they had..........They're working just fine and were under 30 buck
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
