Standard Basecircle for stock LT1 cam.
Old Sep 12, 2004 | 02:30 PM
93SS's Avatar
What is the standard basecircle dia. on stock Lt1 hyd. roller cams. What is a good reduced basecircle cam (dia.) for a stroker buildup for mild Hyd. roller cams for LT1's . Thanks.
Old Sep 12, 2004 | 06:29 PM
1racerdude's Avatar
Re: Standard Basecircle for stock LT1 cam.
Tell whowever is building the cam your engine spects and let them tell you what base circle.I know a .930 will not hit in a 383.
Old Sep 13, 2004 | 03:30 PM
marshall93z's Avatar
i come up with 1.231 for the small lobes and 1.245 for the big ones, if im measuring what is called the base circle? going by what 1racerdude says im not...i guess he is measuring the dia. of the shaft itself. i get 1.051-1.053 for that...hope this helped.
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Jason Short
Jan 19, 2015 06:34 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
