Which stall to get?
Old Jul 30, 2003 | 05:58 PM
Speedy T/A's Avatar
Which stall to get?
yah i know most people get the vigilante but that is too pricey. is the slp one for 400$ ok? What are some other decent ones? Also, is installating tricky for the stall?
Old Jul 30, 2003 | 06:31 PM
revtime's Avatar
I have a TCI converter, I like it, no problems and it cost me about 400.
Install is a pain cause you basically have to pull the tranny but the only thing I think you need make sure of is that the converter is all the way in. Three clicks and make sure you get it on there right, if you have to draw the bellhousing in with the bolts you don,t have the TC in right.
Make sure you put at least a quart of tranny fluid in the TC before you install it or you will burn it up. I put 2 quarts in mine and then put it on.
Old Jul 30, 2003 | 06:32 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
im sure slp makes quality...
hughes is good and a good bit cheaper than vigi.
i had b&m which was even cheaper...
never got the chance to try to break it but.. i would assume b&m makes quality...
tci as well
what stall speed you lookin for?
Old Jul 30, 2003 | 06:37 PM
Cmr0z28's Avatar
midwest......good stuff for only like $430 from summit.
go with a 2400-3000 stall if its a stock car
Old Jul 30, 2003 | 06:41 PM
FastZinTennessee's Avatar
I have a midwest 2800 stall, it rocks!! Got it direct from midwest for $455 shipped. www.raceconverters.com
Call their 800 number and ask for Dennis. He's the guy that builds them, so he can match one up for you. Yes, you get a custom converter for $455 shipped!!!
John
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
