stall?
Old Sep 7, 2003 | 11:45 PM
z28marine's Avatar
stall?
i keep hearing people recommend a "stall". i dont want to sound dumb, but i really dont know what this is? is it for automatics only?
Old Sep 7, 2003 | 11:48 PM
NewbieWar's Avatar
yea, if i understand it correctly it makes u idle at a higher rpms, so that when u let off of the breaks and get on the gas u jump off the line quicker and when u shift it will be at a more torqued rpm and give u harder acceleration.
Old Sep 8, 2003 | 12:00 AM
Red96Lt1's Avatar
It helps you get more into your power band off the line. The way I understand it is if you have a 2800 stall converter, and you power brake it, you will rev to 2800 RPM's and then your car will start creeping. If you are accelerating normally you will feel a delay untill your car hits 2800 RPM's, and then it will start moving. An A4 guy might be able to explain it better to you than I can.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
