Stage 8 bolts question
Old May 31, 2004 | 03:13 PM
IslandZ's Avatar
I just replaced a blown header gasket with a felpro 1406 and this time I use the stage 8 header bolts. I got all the clips on after I tightened the bolts on 'tightly' I couldn't use a torque wrench but they seemed tight enough. Is it still necessary to retighten them? Getting the clips off to retighten seems like a pita. Any insight is appreciated.
TIA.
Old May 31, 2004 | 03:35 PM
94zLT1's Avatar
i think hand tight is ok..they are made for NOT backing out..i havent had to tighten mine once since i installed them
Old May 31, 2004 | 04:17 PM
Johnny-Z-Man's Avatar
Overtighting Header Bolts results in leaking gaskets. Go easy on them!
Old May 31, 2004 | 04:38 PM
flowfx's Avatar
I really need to buy a set of these, I was doing my plugs and just happened to touch one of my header bolts and it was nice and loose.
Old May 31, 2004 | 11:15 PM
Bud M's Avatar
As tight as you can get them with a short wrench is tight enough. With the clips in place they will be fine.
Old May 31, 2004 | 11:46 PM
Dr. Weir's Avatar
Why would you do that? The whole point of the clips is so they can't back out. Therefore they should not be able to loosen.
ChrisFrez
Jan 18, 2015 08:05 AM
importkiller94
Jan 17, 2015 09:03 PM
ChrisFrez
Jan 11, 2015 03:47 PM
97 RedSS
Jun 10, 2003 07:58 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
