Stability/Aligment
Stability/Aligment
I have notice to dangerious level. My car sorta swing very much on road crown. For examlple
1. If there is crown pull on the raod; its almost impossiable control back.
2. I have notice an inch play in steering
3. When ever car come out of bumps; it will try to go out of control
I do have odd tire setup,; but it was doing before too.......
I have now
Front 245-50-16 Dunlop
back 225-60-16 (Snow Tire) Dunlop Graspic(Winter Tire)
I had same problem when I had 285-40-17 GoodYear F1.
I think I need to get check out aligment.
Car can go straight with steering wheel straight.
there is no known wear and tear.
any ideas ?
I have now
any ideas ?
Re: Stability/Aligment
That sounds bad. It might be a bad rack-and-pinion (steering gear) or very loose tie rods. Have the alignment people check these.
I have now
any ideas ?
I have now
any ideas ?
hmmm
What about Caster. u think caster can cause that ?
hmmm
Positive caster should help, not hurt. Zero or negative caster, which I don't think you can get within normal adjustments would make it almost undrivable.
Unevenly worn front tires and/or lots of toe out would make it darty.
Get it to a good alignment shop.
That mean NO dealer and Firestone places ?
I always ask for (and receive) a print out of the "before" and "after" alignment specs on my car.
Good luck.
