SS blowing gaskets
Old Aug 7, 2008 | 09:49 AM
wgilbreath's Avatar
SS blowing gaskets
My '96 Camaro Z28 SS from SLP has blown four head gaskets in twelve year always on the last bolt in front of the driver. The third time the mechanic cracked the block trying to remove the head; coolant return line was clogged. At 20000 miles the new engine blew the gasket at that same bolt. The shop boss thinks the engine is not getting enough air circulation back in that corner by the firewall. What do you think?
Old Aug 7, 2008 | 10:15 AM
JoeliusZ28's Avatar
could a cylinder head be warped from an overheat?
I dont think air circulation is anything to do with it, headers will cook an engine bay and not hurt anything.
Old Aug 7, 2008 | 02:09 PM
MadMike 97 Z28's Avatar
thats where my head gasket blew at too. i remeber that head bolt was hard to get to so i could see how a shop wouldn't get it torqued properly.
Old Aug 7, 2008 | 02:25 PM
JoeliusZ28's Avatar
i didnt have a problem torqueing any of the head bolts on my car
Old Aug 7, 2008 | 02:36 PM
Green96Z's Avatar
You most likely have a warped block deck or head deck. Have them checked. What head gasket have you been using?
Old Aug 11, 2008 | 01:42 PM
wgilbreath's Avatar
New LT1 = $11000 discounted
It would not be a wrapped head because I got a new GM LT1 20000 miles ago. Shop boss said he has seen two other Camaro with that same bolt blowing gaskets. I tried AskQuestion and their Chevy Expert said that the injector may not be set right on that cylinder and it is buring lean and hot. Does that sound logical?
Old Aug 11, 2008 | 03:18 PM
slomarao's Avatar
potentially ya, but i hate those online ask programs. where do you live? You need to go to somewhere that knows LT1's. 4 head gaskets is fu**ing crazy, something is wrong. I was going nuts when i blew one once, 4 times would send me over the edge.
Old Aug 25, 2008 | 02:44 PM
wgilbreath's Avatar
Does anyone else have any suggestions? One guys said something about steam getting into the head.
Old Aug 25, 2008 | 05:27 PM
joeSS97's Avatar
Its possible that the alignment dowel pins are holding the head from seating all the way.May need to drill the holes out a little. I would check that first.
Old Aug 25, 2008 | 05:32 PM
Green96Z's Avatar
I'm going to second that. If the shop cracked your block in the first place, they don't know what they are doing. Take it to a Vette shop or something, then you know the mechanics working on it know EXACTLY what to look for.
Old Feb 13, 2009 | 09:58 PM
Rich2279's Avatar
Just blew a head gasket in the same location!
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
