SS Air Box Question
Old Sep 23, 2003 | 12:04 AM
  #16
Chad96SS's Avatar
Exclamation
You think our induction systems look bad.....check out the underside of a '98 and up SS hood. It has two ducts that have
to route the air back around to the front of the hood, then
pass through some rather small inlets. They should have
used SLP's Ultra Z hood. It might not be the prettiest, but
it at least has a more direct route to the airbox.
Old Sep 23, 2003 | 09:52 AM
  #17
Brent94Z's Avatar
Super Moderator
Originally posted by RamAir95TA
- Air is incompressible at any automobile speed., meaning that the kinetic energy of the air cannot be used to compress the air and raise the static pressure.
You sure about that?
Old Sep 23, 2003 | 12:27 PM
  #18
FacelessZ's Avatar
Originally posted by onefast95Z28
i will be going with the SS induction simply for ease of removal/cleaning/etc......the K&N is just too much of a pain.....i may be doing it the hard way, but i pull the splash panel off the drivers front to get to it....
Yea getting on the ground and removing a cone filter is SOO hard to do...let's not forget that the entire airbox was removed in order to fit the K&N cai, which means that the filter is easily accessible DIRECTLY behind the air dam...
Old Sep 23, 2003 | 01:11 PM
  #19
Twice The Fun's Avatar
maybe im not understanding this correctly, but it sounds like youre being a smartass about this.....i just feel it would be much easier to pop open the hood, remove the filter above the intake, clean it and replace, instead of getting underneath the car, pulling off the splash guard, loosening the clamp on the filter, and putting it all back together....
Old Sep 23, 2003 | 01:34 PM
  #20
FacelessZ's Avatar
smartass is one way of putting it
Old Sep 23, 2003 | 04:07 PM
  #21
1996 | Z28 SS's Avatar
I've had both systems. My old SS box was cracked and worn so I replaced it with a K&N cold air. Yeah sure the filter is harder to get at and clean. But honestly how many times can you clean a filter a year? And I do believe the SS one has very little ram air effect. Most of the air flows over the scoop as I'm told. And once again yeah sure, so maybe it's getting colder air from the outside, but it sits right on the intake, and I must say that sucker gets pretty hot, pretty fast. So any cold air I think just gets heated anyways. When I felt my K&N after installing it, the plastic was actualy cold! Thats what convinced me it's better. And about only getting air through 6 little slits in the guard, just cut a whole and put a scoop. A lot of people will say "no your going to risk getting water in" but unless you're driving through a puddle (as in the front of your car is under water) then water isn't going to be a problem. Just my experiences...
Trevor
Old Sep 23, 2003 | 10:31 PM
  #22
alright then smartass, explain what your point was in the first post???
LT14LIFE
Feb 9, 2015 09:35 PM
95chwagon
Jan 13, 2015 09:19 PM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
