Squealing noise. Alternator going out?
Old Jul 6, 2004 | 01:40 PM
Cmr0z28's Avatar
Alright guys, the first 5 minutes my car is running I have a loud squealing noise. Sounds like a bad bearing or something. Today I took it out, and it was squealing louder and longer than usual, and the battery voltage was pretty low and my turn signal was blinking slowly. I also have a miss at idle and when I hold it at 1000-1200 RPM's, but that could be anything. I just changed the plugs 3 days ago and no wires are burnt.
Suggestions?
Matt
Old Jul 6, 2004 | 03:28 PM
94Zpower's Avatar
maybe the spring in your tensioner pulley is worn out and its causing y our belt to slip and squeal?? just a thought.
hope its nothing serious.
Old Jul 6, 2004 | 05:17 PM
Cmr0z28's Avatar
Well the belt isn't slipping, just a squealing noise. The tensioner is a year old, and I'm not sure what brand it is. My uncle changed the belt, tensioner, and the crank pulley when my crank pulley split in 2 up in NY on vacation last year. The replacement tensioner has a plastic pulley and definitely doesn't look as sturdy as the stocker, but what would explain my battery voltage dropping?
Old Jul 7, 2004 | 04:11 PM
Cmr0z28's Avatar
Ok, I used a stethascope, and I can't hear any loud squealing coming from the alternator, tensioner, or the AC compressor. What do I do now? Would a cheap belt cause squealing when cold? I guess I'll go pick up a new Goodyear Gatorback and a new tensioner....
Old Jul 7, 2004 | 05:33 PM
Cmr0z28's Avatar
Just got the Gatorback on, and there's no noticeable squealing. I'll let it cool down fully and start it up in a few hours and let you guys know.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
