Squeak from engine
Old Aug 10, 2005 | 09:54 AM
jbrunocoon's Avatar
Squeak from engine
I have a 1997 Camaro Z28 with a LT1 with 177,000 miles on OEM engine and have run Mobil 1 exclusively. I have a squeak that seems to be coming from the middle of the engine. I have replaced the water pump, and removed the serpentine belt while running the motor to eliminate other accessories like the alternator, a/c compressor, etc. and the squeak persists. The squeak is a rythmic intermittent squeak definitely tied to engine rpm. It continues whether in park or when driving, seems worse once the engine is warmed up. Oil pressure, looking a internal dash guage, seems to be fine. I had noticed a bit of a tapping noise in the past prior to the squeak. It is definitely getting worse. Any ideas or suggestions?
Old Aug 10, 2005 | 10:51 AM
Valkyn71's Avatar
Re: Squeak from engine
Im no expert but it sounds like a bearing
Old Aug 10, 2005 | 02:31 PM
Crazy95Z's Avatar
My best guess would be the gear for the water pump drive shaft. I'm sure after 177,000 miles, it probally needs replaced.
Old Aug 12, 2005 | 05:28 PM
IKILDVPRKILLER's Avatar
My engine was doing the same thing and it was the harmonic balancer.
It was spining within the hub and when there was a load such as the ac...it was worse....at fist it was intermitent then it got worse and when it went out it was bad. So I would check that first. Pull your belt off again and check it to see if the rubber bushing inside is bad.
Old Aug 12, 2005 | 05:47 PM
jbrunocoon's Avatar
The crankshaft balancer was a good idea, but, I had the problem and replaced it with a new one at 150,000 miles. This squeak is definitely in the engine. I have removed the serpentine belt and the squeak persists. My ASE mechanic friend tells me, the he thinks it is a bad hydraulic lifter on #3 or #5 piston. His recommendation was to first try an oil change and put in a quart of lucas oil treatment with 4 quarts of oil. Warmed the engine up good and the squeak is still there, but he thought it might take a bit for it to work into the lifter. I also checked the oil that I drained and found no metal shavings or particles in the oil.
Old Aug 12, 2005 | 06:07 PM
I dunno man. Some times the oil pressure will fall with a spun bearing. Just from my experience if the squeak is loud enough to hear and your oil is good. Chances are its not a bearing. The way the motor is set up there could be harmonics coming from any where. When do you hear the squeaks
Old Aug 12, 2005 | 06:10 PM
Oh yea the lucas is a personal preference some like it some don't. I would continue with normal oil. My motor has 183k on it and I have always run AC delco oil filter with castrol 10/40. My car runs just about as hard as it ever has.
Old Jan 2, 2006 | 11:38 AM
jbrunocoon's Avatar
Turns out that my squeak in the motor was a bad lifter and worn camshaft on the #5 cylinder. I have included a link to a photo. Put in a new Comp cam, lifters, rockerarms, timing chain and gears, etc. and it runs great.
Old Jan 2, 2006 | 11:40 AM
jbrunocoon's Avatar
Here is the link: http://home.comcast.net/~j.bruno.coon/camarocam.html
Didn't seem to post right.
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
RichJ
Sep 26, 2002 09:43 AM
Christopher
Sep 14, 2002 03:08 AM
rod442
Aug 26, 2002 01:22 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
