"square" or "flat" o2 sensor connections on 97????????
Old Jan 26, 2004 | 06:42 AM
QUASAR BLU's Avatar
Summit sells casper electronics 02 sensor extensions in 95-96 f car and 97-02? My buddy just got them in and they are square? The 02 sensors we have laying around have flat connections. The car is currently in storage so we cant look at the car.
So what kind of connection for the FRONT o2's on a 97 SS?
THANKS!!
Old Jan 26, 2004 | 07:10 AM
AsianSensation's Avatar
You need 4 pin flat.
Old Jan 26, 2004 | 07:42 AM
QUASAR BLU's Avatar
Thanks AsianSensation
Can anybody second this? Because if so summit has them in their book wrong and has had them that way for a long time.
My freind says the best he can remember there were some square connections down near the k-member but he only remembers seeing one flat style one. (motor has been out of the car) However the o2 sensores we have in ziploc bags do have flat style connections. So wtf are those square LS1 style connectors in the harness for just hanging there? Does anything else use the square style connector on a 97?
Old Jan 26, 2004 | 07:48 AM
Hyperspeed97z28's Avatar
On my 97 the FRONT o2's are FLAT, and the REAR o2's were Square.... I have since then had the rear deleted out of the pcm...
Old Jan 26, 2004 | 07:51 AM
Javier97Z28's Avatar
Moderator
That's correct. Ditto here, back ones are deleted from the PCM.
Old Jan 26, 2004 | 08:40 AM
97Z-pimp's Avatar
same for me...front are flat, and rear are square.
Old Jan 26, 2004 | 08:42 AM
QUASAR BLU's Avatar
Ok it makes sense then....
GM must have been in the process of changing over or something. 96-97 gets flat front o2's and square rear o2's, and 98+ gets all square. What a clusterfu(k.
The responses here have always been quick and great thanks a million
Old Jan 26, 2004 | 09:04 AM
GM must have been in the process of changing over or something. 96 and older get all flat, 97 gets flat front o2's and square rear o2's, and 98+ gets all square. What a clusterfu(k.
AFAIK, all 96-97's have flat fronts and square rears. Never heard anyone say any different.
Old Jan 26, 2004 | 09:22 AM
WS Sick's Avatar
Same here on my 97 WS6 T/A.
Old Jan 26, 2004 | 10:19 AM
QUASAR BLU's Avatar
Ok, I've edited my post to reflect 96-97. Thanks!
Old Jan 26, 2004 | 10:35 AM
Hotwire's Avatar
i hope you don't plan on runnin the o2 sims on the front, it won't work. that means your computer would be guessing at the afr and most likely not run right.
Old Jan 26, 2004 | 10:46 AM
QUASAR BLU's Avatar
There will be no rear o2's on the car, they will be programmed out along with all the other emmissions components. We will be putting the front o2's back in. Unless we can program it well enough to run in open loop all the time
The confusion was when summit sent square o2 extensions to us instead of flat ones. It is misprinted in their book. Casper electronics o2 extensions for 97-02 cars is what we ordered. Its obviously wrong.
Old Jan 26, 2004 | 11:09 AM
Hotwire's Avatar
if ya can do a little soldering, I have the schematics for the o2 simulators, costs about $15 for the parts down at radio shack, I'm running the circuit on my 97 s-10, works fine.
Old Jan 26, 2004 | 11:43 AM
QUASAR BLU's Avatar
If ya got those schematics in pdf or something shoot them over to me jcece@wowway.com
thanks
Old Jan 26, 2004 | 12:37 PM
thanks
Please send them to kfarron1581@aol.com as well
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
tbyrne
Aug 16, 2002 01:12 PM
