Spun rod bearing. What to do
Old Apr 8, 2010 | 01:42 PM
fast-enough's Avatar
Ok well I've never really posted here before but the 3 days ago I purchased a 95 z28 and on the way home it blew a head gasket. I yanked the heads off of it and it appears the heads have been milled and when they reinstalled the heads they had sit the corner of the head on the gasket puncturing it. I purchased the car just to drive for a bit and build overtime. So i checked the heads and reinstalled them. And after I got it going again it spun a rod bearing. I have a carb'd 327 I built a few years back thats ready to go and a th400 trans. My issue is should I modify everything to run this setup, which appears to be alot of work. Or should I build another lt1 to run in the car. Any inputs appreciated. Thanks
Old Apr 8, 2010 | 02:08 PM
bombebomb's Avatar
Seeing as this is an LT1 section, I think you will get a lot of biased opinions, including mine
Stay with the fuel injection.
Only way I would go a different route is if the motor was larger than a 327, you was not going to drive it much, you had huge power goals that LT1 style heads can not reach.
Old Apr 8, 2010 | 02:16 PM
Well the 327 i built for a nova i used to have and it put down 415 to the wheels it has double hump heads. I was just considering it as an option, since its just sitting on a stand and i have a wad of money tied up in it. Im just sorting through the ideas. Im more than certain by the time its said and done ill end up going with a forced induction lt1.
Old Apr 8, 2010 | 02:23 PM
Consider the room needed for the carb and the rear distributor.
Old Apr 8, 2010 | 02:29 PM
Which is why I was saying I'll probably go with an lt1, the carb clearance doesnt look awful, but the distributor I just wouldnt know how to make work without getting nasty about it. The cars just going to be a clean summer weekend car and I dont really want to hack it up.
Old Apr 8, 2010 | 03:12 PM
And what issues would i run into by installing a 96 lt1 out of a camaro into the 95?
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
