Sprung a radiator leak
Old Mar 13, 2008 | 08:14 PM
Finchinater's Avatar
So it's close to 60* today in ohio, so i fired up the camaro to take a couple of laps around pictown. Took it back to polish up the wheels and all of a sudden I hear water streaming underneath my car.
Water was streaming from the plastic framing on the radiator directly under the cap. It ran a little hotter than normal, but I attributed this to city driving, but temp usually isn't that high. Wasn't even close to overheating, but was hotter than normal. Is this fixable or do I have to put a new one in?
Thanks in advance gurus.
Finch
Old Mar 13, 2008 | 08:16 PM
dangalla's Avatar
i would replace the rad, if it were in the metal you might try some stop leak, but i would never use that stuff in mine
Old Mar 13, 2008 | 10:28 PM
sz28's Avatar
Yeah I'd say new radiator stop leak seems to gunk everything up in your rad/engine.
Old Mar 13, 2008 | 10:30 PM
NovaTodd's Avatar
If they are still available, you can replace the plastic tank. I did mine about 4 years ago. It is a pain in the rear to straighten what seems like 50 aluminum tabs out and them tighten them back up - but knock on wood I have not had a problem yet.
Old Mar 18, 2008 | 11:49 PM
Guess I don't really know how my radiater is built. The plastic on the sides are covering what exactly and can I just solder the hole shut without pulling it or replacing it. Not part of the budget for the moment, so I would like a permanent fix.
Any good pix of a radiator pulled from a car?
Thanks.
Old Mar 19, 2008 | 07:02 AM
The side tanks are plastic. Patching one might be a little iffy. The core is aluminum.
http://shbox.com/1/radiator.jpg
A new radiator is less than $200.
Old Mar 19, 2008 | 10:00 AM
mdenz3's Avatar
I've fixed a radiator that had the plastic sides crack with JB weld before, lasted for at least 14 months including 10+ road trips.
Old Mar 20, 2008 | 07:27 PM
Thanks Shoebox. Picture helped out alot.
Radiator sprung a leak just above the #8 part. I'll just replace it, that way I know it will be fixed the right way.
calaban
May 18, 2020 06:43 PM
pimpen1024
Aug 19, 2015 08:36 PM
SergheiS
Jul 5, 2015 03:27 AM
squirrels
Aug 6, 2002 08:50 AM
