Springs to use with CC306
Old Mar 20, 2007 | 12:15 AM
RyanD's Avatar
I originally bought some comp 986's, but they won't fit my stock heads without some grinding, which I'd rather not have done. What springs should I use that will fit my stock heads and be able to work with my cam?
Old Mar 20, 2007 | 12:35 AM
hotrod18_69's Avatar
I'm using the Crane 10308 kit..
But you can use Comp Beehives as well. Do a search for both and you'll come up with alot..
Old Mar 20, 2007 | 08:29 AM
zx1216's Avatar
918 beehives, no machining needed...
Old Mar 20, 2007 | 08:35 AM
Z-RATED94's Avatar
I forget, what's the lift of the 306 with 1.6 rockers? RyanD, if you can use the beehives with that cam, which I believe you can, do it. I had some 987s with my small cam and they weren't enough spring for the job. The 918s solved the valve float problem. Gained another 400 rpm.
Old Mar 20, 2007 | 11:48 AM
RyanD's Avatar
I'm using 1.5 crane gold rockers, with this lift do you think 918's would work? btw man, thanks for the help.
Old Mar 20, 2007 | 12:09 PM
zx1216's Avatar
check my sig, everything works flawlessly up to 6900, btw the 918's are good to .600 lift and the cc306 is like .544 intake, .576 exhaust with 1.6 rockers.
Old Mar 20, 2007 | 12:55 PM
RyanD's Avatar
edit: noticed you have an m6. nevermind, thanks for the help
mightymouse383
Jul 20, 2016 07:34 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
