Springs for hotcam
Old Jan 12, 2008 | 05:07 PM
CamaroSS8887's Avatar
Springs for hotcam
What springs for the hotcam already have the cam.
Old Jan 12, 2008 | 05:12 PM
Jazsun's Avatar
LT4, make sure you get LT4 retainers/locks don't reuse the LT1 stuff.
Old Jan 12, 2008 | 10:31 PM
z275plus's Avatar
Get the Isky's from thunderracing they are good for 550 lift which would be more than enough for the hotcam.
Old Jan 13, 2008 | 09:10 AM
96capricemgr's Avatar
You are wrong, the LT4 springs are marginal at best for this cam. They may be OK with the lighter LT4 valves but on an LT1 they do not really maintain great control for long.
This the weakest spring anyone bothers to put on these heads other than stock, long as you buy one of the aftermarket options pretty much anything is going to be a little stiffer and work better.
Loom into the Isky's mentioned above, maybe look into the ones Crane lists for the aluminum heads, either will be good. Beehives are an option too.
Old Jan 13, 2008 | 01:49 PM
96' Formula WS6's Avatar
Not to hijack or anything but are the springs that come with the hotcam kit sufficient. I have heard that the lt4 springs that come stock are pushing it close with the lt4 cam, why would gm do this.
Old Jan 13, 2008 | 01:57 PM
95camarodude's Avatar
lt4 hot cam springs are good for up to .600 lift. i have the whole kit. they are awesome i was impressed. stomps on ls1 anything. but i also have every bolt but a supercharger.
Old Jan 13, 2008 | 03:24 PM
Stl94LT1's Avatar
WOW, are you misinformed!!! They LT4 springs are marginal at .525 lift.
Old Jan 13, 2008 | 04:40 PM
As I said they may be OK with the lighter LT4 valves but not with the LT1. GM did this bec ause they were already in the parts bin, same reason they use the LT1 TB on the Ramjet 502. Doesn't mean it is right.
You really don't want to take any advise from the guy above that thinks they are good to .600, those are probably V6 cars he is racing.
Old Jan 13, 2008 | 05:36 PM
truedualws6's Avatar
The Isky 235-Ds are a good, low cost, stock replacement size spring. They
are good up to .550" lift.
HarleyZ28
Oct 5, 2015 06:23 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Catmaigne
Jul 14, 2015 05:17 PM
k1996z28
Apr 13, 2015 06:54 PM
