spraying gas out !
Old Jul 14, 2004 | 12:15 PM
Robert_K's Avatar
Exclamation spraying gas out !
When I open the shrader valve cap my car immediately releases the fuel pressure and sprays it out right there. Is'nt the cap supposed to come off without releasing the pressure? I was thinking a pin or something had to be pushed inside the actual schrader valve to release the pressure.
Old Jul 14, 2004 | 12:30 PM
GetaZforgetGT's Avatar
There is a pin, just like a tire valve stem that releases the pressure.
When you take the cap off nothing should happen.
Old Jul 14, 2004 | 01:00 PM
LWillmann's Avatar
If your car is missing the valve itself, run down to the parts store and pick up a new core. They're the same type that are in car tires.
Old Jul 14, 2004 | 01:44 PM
Robert_K's Avatar
When I bought the car it did not do this the first time I tried. I started hammering at it and messing with it. I thought the pin had to be pushed down to release the pressure. I'll have to check if the sem is still down there and if I can get it out. How do you release the pressure normally?
Old Jul 14, 2004 | 01:47 PM
Originally posted by Robert_K
... How do you release the pressure normally?
Like letting air out of a tire.
Old Jul 14, 2004 | 01:59 PM
Robert_K's Avatar
I see. Thats what I was doing, or trying. I think there is'nt one in there. does running the car without a stem do anything to the fuel pressure? I really need to check my fuel pressure but need a gauge. The cheapest ones here go for around $40. Thats a little steep for me just to check the pressure one time. I can buy a fuel pump or regulator for that price.
Old Jul 14, 2004 | 02:01 PM
You can throw parts at it, but you still won't know what the pressure really is. It's a tool that you must have if you want to troubleshoot a modern fuel injected engine.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
