splayed cap ??
Old Jan 30, 2005 | 07:46 PM
93black-ta's Avatar
splayed cap ??
has anyone had problems with oil pan clearance when using splayed 4 bolt caps? my caps are hitting the sides of my stock oil pan right at the engine block. does anyone know if an aftermarket pan would have more room in this area?
Old Jan 30, 2005 | 07:48 PM
sleepy_z28's Avatar
Re: splayed cap ??
I'm sure the Canton pan clears, but I went slightly cheaper and bought the Milodon 7 qt cap. pan.
Old Jan 30, 2005 | 07:52 PM
LT4383's Avatar
Re: splayed cap ??
I'm using the canton pan, no problems so far.
Old Jan 30, 2005 | 08:04 PM
93black-ta's Avatar
Re: splayed cap ??
do you know the part # for the milodon pan or who sells it. ive searched for it with no results
Old Jan 30, 2005 | 11:27 PM
sleepy_z28's Avatar
Re: splayed cap ??
The part number for the pan is 30902 and the matching pick up tube for the oil pump is 18314 and that tube fits my Melling HV oil pump. I bought mine from the local speed shop, both pieces were about 180 bucks together.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
