Spin your front wheel....
Old Nov 19, 2003 | 02:45 PM
madwolf's Avatar
Arrow Spin your front wheel....
If anyone has their front end jacked up, could you please spin one of your front wheels for me?
I don't remember exactly how it should be normal, but I think it is supposed to spin freely... Am I right?
Thanks.
Old Nov 19, 2003 | 02:51 PM
OutKast's Avatar
should spin freely unless you have your foot on the brake or have warped rotors or bad bearings. E-brake only goes to the rear. Ever tried to take off the front lugs when the car was already up? Doesn't work so well unless you've got an impact.
Old Nov 19, 2003 | 02:55 PM
madwolf's Avatar
Yea, I remember on my '95 they were very easy to spin, but on the 93, they're pretty hard. Seems like the brake pads/rotors is the problem since I can hear the friction between them. I wonder why though.
I would think with warped rotors it would be a pulsating (for lack of a better word) rub, but mine is constant and on both wheels. Maybe the pads were installed wrong or perhaps they're not even right for this car?
Thanks.
Old Nov 19, 2003 | 03:07 PM
NoFear95's Avatar
Sounds like your calipers are sticking.
Old Nov 19, 2003 | 03:14 PM
OutKast's Avatar
Sounds more like your calipers might be sticking.
Old Nov 19, 2003 | 03:16 PM
Heatmaker's Avatar
Advanced Member
I think your calipers are sticking
americanmusscle's Avatar
Is there an echo in here??
OutKast's Avatar
doh, I concur
Old Nov 19, 2003 | 03:19 PM
OutKast's Avatar
If I remember correctly...93 has slightly different brakes than the later years. I want to say that they're smaller but maybe an echo will confirm.
Old Nov 19, 2003 | 04:07 PM
madwolf's Avatar
Yep, I think they're different too. What do you mean by caliper sticking? Piston not backing out all the way? If so, what's the cure?
Thanks!
Old Nov 19, 2003 | 05:08 PM
OutKast's Avatar
yep, not backing out. They can be rebuilt or replaced...I've never tried to rebuild them so I don't know the details.
Old Nov 19, 2003 | 05:18 PM
NoFear95's Avatar
You can pick up rebuilds at Auto Zone etc.. They are cheap and easy to swap out.
Old Nov 19, 2003 | 05:41 PM
Mine have never spun as freely as I think they should, but I have never had any trouble or excess wear.
Old Nov 19, 2003 | 05:43 PM
madwolf's Avatar
I just looked on autozone's website and they charge $38 per caliper. Not too bad I guess. (minus cores)
I might just replace them. Do you have to bleed the entire system afterwards or just the front channel?
Thanks!
PS. The reason why I even bother is because I think I'm losing a little bit at the drag strip because of them.
Old Nov 19, 2003 | 05:58 PM
will62085's Avatar
Thanks!
just the fronts will need bleeding, and very little bleeding since you will only be loosing a little fluid at the very end of the line
