Spec Stage II + N2O + ET Streets - will it hold?
Old Aug 4, 2003 | 01:35 PM
HungryT/A's Avatar
Hi there,
I've got a bolt on T/A, no major mods. However I'm sprayin a 100-shot, and want to hook with ET Streets.
I don't want to "over-clutch" my car since it's driven daily.
What do you think, will a Spec Stage II be sufficient for sprayin out of the hole? I don't "want" to get the $tage III....
Thanks!
Old Aug 4, 2003 | 02:20 PM
Fastbird93's Avatar
With your M6, don't even think about it. M6 + LT1 with bolt on's + 100 shot = tranny
Old Aug 4, 2003 | 02:29 PM
HungryT/A's Avatar
I thought these T-56's can hold up to 600-700 hp without blowing up!
Are you sure??
Old Aug 4, 2003 | 02:37 PM
GetaZforgetGT's Avatar
I wouldn't worry so much about the tranny. It should be able to handle it.
The rearend is where I would be concerned.
ET streets plus a spec clutch are going to put one heck of a load on the stock 10 bolt...add 100 shot to that and you might break it off of hard launch.
If you lauch it at a reasonable rpm and then spray it you should be ok. The initial shock off the line could be the end of you stock rear.
Old Aug 4, 2003 | 02:43 PM
NVetro's Avatar
As for your star spec question, I have a stage 2 and it can handle around 450 to 500 rwhp. I SUGGEST!!! You get a new flywheel, DO NOT recut your OEM one. Aftarmarket clutch + Cut flywheel = bad. I got their lightweight flywheel also. Can REALY notice the diffrence when rpms are climing.
Old Aug 4, 2003 | 02:51 PM
HungryT/A's Avatar
Yeah, I think Fastbird93 must have been thinking about the rearend. I will try to keep the rpm's down when launching, but I already see a broken 10 bolt in my mind...
NVetro, thanks for your suggestion!
Old Aug 4, 2003 | 02:52 PM
cmbob67's Avatar
Don't do it!!!!!!!! These crappy rear end's don't hold up for nuthin. A buddy of mine was running 13.4's in a 96 Z-28 M6 with all bolt on's, drag radials, No NO2 and BOOM!!!! tick, tick, tick, tick, tick...... If your runnin a M6 you should be pullin off the line pretty quick as it is. Don't hit the juice untill 2nd gear and you should be fine.
Old Aug 4, 2003 | 04:11 PM
Fastbird93's Avatar
Originally posted by Fastbird93
With your M6, don't even think about it. M6 + LT1 with bolt on's + 100 shot = rear end
EDIT=I've been brainfarting like that all day for some reason. Lack of sleep is my alibi.
Old Aug 4, 2003 | 04:26 PM
rpm4lalo's Avatar
Good advice.
I wait until second gear spray as well, but with the 10 bolt, it is just a matter of time before it breaks at the 1/4 with the ET Streets anyway.
Old Aug 4, 2003 | 08:08 PM
Derrick Redd's Avatar
M6 + nitrous + traction = 10-bolt
Old Aug 4, 2003 | 08:17 PM
jasons93z's Avatar
If you want to spray out of the hole then i would rethink the et's because if you hook with the stock rear-end then goodbye rear.
Old Aug 4, 2003 | 08:55 PM
drewstealth's Avatar
Good glad to hear it that it is ONLY the rear end that will break. But anyways where is a good place to find built up t-56's or is it just better or more economical to just get the stocker rebuilt. Sorry for stealing your thread hungry. I wouldn't spray off the line. You can get good enough times without spraying off the line.
Old Aug 4, 2003 | 09:01 PM
jasons93z's Avatar
Nobody said that it is the ONLY thing that would break. These t56's are damned strong(but they can still break), the rear-end is just the weakest link.
Old Aug 4, 2003 | 09:12 PM
Yeah i think i was used the wrong smile face thing there. I was trying to mean that it sux that the rears are so crappy. I didn't word it right.
Old Aug 4, 2003 | 09:14 PM
jasons93z's Avatar
thats fine . Ooops
