Sparks!!
Old Feb 2, 2003 | 09:57 PM
DAC350's Avatar
Sparks!!
So I was changing the #2 plug today, and I angled the wrench a certain way and BOOM, sparks flew all over the place. I know, should of disconnected the battery, my bad. The sparks actually gouged the wrench. What would of caused this around the #2 plug? Do I have a bare none plug wire around there (sensor wire? accessory wire?) All the plug wires look fine. I couldn't see any other kind of wiring other than the plug wires..... Thanks.
Old Feb 2, 2003 | 10:10 PM
Alternator or starter cable, depending on where you were swinging your wrench. I'm sure you jumped out of your skin!
Old Feb 3, 2003 | 12:40 PM
DAC350's Avatar
So since the wires sparked does that mean they are ok, or are they bare and need to be replaced? Thanks.
Old Feb 3, 2003 | 01:17 PM
Depends on where and what you hit. The connection on the back of the alt should have a rubber boot to keep it insulated from this kind of thing. The only other place I can think you might have hit is the stud on the starter. It has no protection. If you have a wire bared somewhere, you should find it, check for damage, replace or tape it up.
Old Feb 3, 2003 | 01:20 PM
97Z-M6's Avatar
did you change your pants after you pissed in them. it dont hurt but you almostfeel like you are going to have a heart attack
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
