Spark tester.... how much gap?
Old Dec 14, 2004 | 02:50 PM
lt4 fd's Avatar
Hey I got a spark tester and was wondering what is the appropriate minimum gap the spark should jump on the LT1?....30mm?
Old Dec 14, 2004 | 03:31 PM
Z06Z28's Avatar
Re: Spark tester.... how much gap?
you talking about a spark plug gapper? .045 for plugs I believe...
Old Dec 14, 2004 | 11:43 PM
Well, stock gap is .050, so I would use that for simulation.
Old Dec 15, 2004 | 09:46 AM
lt4 fd's Avatar
no not spark plug gap im testing the power of teh ignition system since I dont know why my car wont run and I set the gap at about an inch and the cylinders I tested jumped it.... damn this car.
Hey shoebox do you know if you can test fuel pressure when just cranking the motor or does it only come up when you prime it and once it starts running?
Old Dec 15, 2004 | 09:52 AM
OBE1 95Z28's Avatar
I believe my spark tester came witha a guide that show distance based on coil voltage. I'd estimate the stock coil should produce at least 30K volts so I'd look for a gap to match that. I help fix a friend's car that had a bad coil; the coil would jump a spark about 1/4", but not start the car.
Old Dec 15, 2004 | 12:03 PM
A static test can be made by connecting a pressure gauge and priming the system. If you prime it several times, you should see pressure in the normal range. You can also run the pump continuously by applying 12v to the fuel pump prime connector by the RH shock tower. Engine running tests should also be done for a complete picture. There is a small article about fuel pressure on my "how to" page.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
