Spark tester.... how much gap?
Re: Spark tester.... how much gap?
no not spark plug gap im testing the power of teh ignition system since I dont know why my car wont run and I set the gap at about an inch and the cylinders I tested jumped it.... damn this car.
Hey shoebox do you know if you can test fuel pressure when just cranking the motor or does it only come up when you prime it and once it starts running?
I believe my spark tester came witha a guide that show distance based on coil voltage. I'd estimate the stock coil should produce at least 30K volts so I'd look for a gap to match that. I help fix a friend's car that had a bad coil; the coil would jump a spark about 1/4", but not start the car.
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
