Spark Retard Question...
Old Jun 7, 2004 | 09:17 AM
SteveZ Z-28's Avatar
I have a 1994 Camaro Z-28 and have noticed that I don't think that my car is running quite right. I just replaced my spark plugs because I thought that it could be the problem. Well, it seems like when I am in like second or third gear and driving at low RPM's under a load, like going up a small hill, the engine lopes. I noticed using DataMaster that the spark advance graph goes up and down at that point, somewhat similar to a sinusoid wave. Usually it only lasts for a second or two and evens out. Also, I have notice that when I accelerate moderate to aggressively I get spark retard. When I was going about 20 or 30 mph and then basically floored it, I got like 4 degrees or so of retard. When I am going at a steady rpm i don't have any retard, same is true when I accelerate slowly. Is this normal behavior? I am not getting any DTC's. The only mods that I have are the ones listed below.
Old Aug 7, 2004 | 07:28 PM
Re: Spark Retard Question...
Anyone have ideas on this problem? I am still having it.
I have also noticed on the Histograms that I have a rich condition in both short and long term counts on both left and right sides. The RPM ranges vary, but are usually on the low end, from about 750-2500.
Thanks in advance.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
