spark plugs harder on S10
Old May 7, 2006 | 05:28 PM
pearlpurple's Avatar
Move this to the lounge if you wish but I thought I would share this with you LT1 guys who think our cars are hard to change plugs.
I can assure you that my 2000 S10 with the 4.3 Vortec believe it or not,,, is waaaayyyyy harder,,, stupid #3 plug is right behind where the steering shaft goes down to the steering box.
I moved the master cylinder out of the way, removed the breather, mass air flow sensor and air filter box just to make room to work. With the limited tools I cut a spark plug socket shorter as you cannot even get a full length one on the plug because of the steering shaft.
At least on the LT1 every plug is accessable.
Old May 7, 2006 | 05:31 PM
Spitfire557's Avatar
Re: spark plugs harder on S10
I have a '96 Blazer (4.3 Vortech also) and the plugs weren't all that bad actually. I had to take out the fender wells to get to some of them, but other than that, it was easy. I did the plugs on my LT1 during the header install, so it was EASY.
Old May 7, 2006 | 09:00 PM
Yeah, it will get moved...
Old May 7, 2006 | 09:29 PM
my94blackz's Avatar
What he said! Jack it up and go through the wheel wells.
Old May 7, 2006 | 10:00 PM
sbs's Avatar
sbs
99 Diamante. Intake manifold and all the crap attached to it have to come off to change plugs on rear bank.
Old May 8, 2006 | 01:27 PM
Dave Holland's Avatar
I've got a 96 Blazer as well. Plugs are a piece of cake. They are all easily accessed through the wheel wells. The one behind the steering shaft isn't bad either if you know the trick. Put a spark plug socket on it, one with a hex head on the end, put a stubby wrench on the socket, and pry against the exhaust manifold. Easy.
-Dave
Old May 8, 2006 | 08:03 PM
-Dave
manifold or steering shaft must be slightly different in the 4 years difference because I have been working on cars for 20 years and if it were a piece of cake I wouldn't be whining about it.
Yes plugs 1, 2, 4, 5, 6 are all a piece of cake.
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
