Spark Plugs backing out?
Old Apr 7, 2005 | 09:22 PM
97WS6Pilot's Avatar
After installing plugs (tr55's) in my LT1 I've had two of them get loose enough to turn by hand. Should I have used Loctite? I'm afraid to torque them too tight in an aluminum head.
Old Apr 7, 2005 | 09:25 PM
camarolover20's Avatar
Re: Spark Plugs backing out?
I had to tightin mine down for a lil over a month bc i didnt wanna make them to tight also.I m pertty sure you cant use loctite bc it will turn the threads out
Old Apr 7, 2005 | 10:42 PM
brandboZ28's Avatar
I just had the same problem with mine 3 days ago. I had 3 back out in the middle of a road trip. Luckily I had my tools so I tightened them back down and went along my way. I have since swapped to Autolites.
Old Apr 7, 2005 | 10:44 PM
Joe Bellman's Avatar
I wouldn't use loctite, they will be a real pain to take out later. Just tighten them back up again. BTW, I have had mine do that a couple of times too.
Old Apr 8, 2005 | 10:40 AM
97WS6Pilot's Avatar
I'll bet there are a lot of cars running around with loose spark plugs and don't even know it. I just happened to check because I had it on a lift. Has anybody ever had a spark plug completely come out? Does it cause damage? I'll bet its gets loud as hell .
Old Apr 8, 2005 | 11:43 AM
Camaro97USAF's Avatar
I wouldn't think it'd be loud, since theres nothing to spark da boom in the cylinder, ya know? So maybe just like the sound of air being pushed out the spark plug hole.
Old Apr 8, 2005 | 12:03 PM
Jasonz28camaro's Avatar
its pretty damn loud
ask me how I know
Old Apr 8, 2005 | 01:09 PM
pillagenburn's Avatar
If you can get to it, what I would do is put anti-seize on it, tighten it down to what you want, then put some orange or black RTV (pref. black) .... just a small bead of it between the spark plug socket fitting and the head - let it cure over night and BAM ... no more back-outs....... if you get it on there right :P
notice i didn't say put RTV in the THREADS ... that would be disasterous!
Old Apr 8, 2005 | 01:14 PM
valter's Avatar
It's loud. That was not LT1, it was my friends 4.6 ford Crown Vic, common problem. Plug with coil were jumping like crazy around the hole, and he drove that way like 50 miles.
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
